2 members (Hush, Forty9),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 86 Shop Shark | | Shop Shark Joined: Feb 2010 Posts: 86 | I bought a supposed to be a 89 305 out of a van at the auction. Can someone break down the block numbers for me.V1216TWB I need to order parts so I need to make sure what I have. thanks | | | | | Joined: Feb 2010 Posts: 86 Shop Shark | | Shop Shark Joined: Feb 2010 Posts: 86 | I know the V is flint Micigan. The 12 and 16 are dates. But what is the TWB stand for in 1989??? thanks | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I see nothing with letters for block castings. All info I have shows 8 numerals. Only 89 is for a car with roller cam. Are these numbers/letters from the rear of the block? | | | | | Joined: Feb 2004 Posts: 29,767 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,767 | I assume the numbers are stamped on a machined pad on the block ahead of the passenger's side cylinder head? The 3-letter suffix should tell you the year and engine size if you can find the right cross-reference chart. "T" in that suffix code means it's a truck engine, but I can't seem to find the reference chart online that I usually use.
The casting number (not a stamping) at the back of the block just above the bellhousing bolt circle on the driver's side is probably a better way to do your research. On older blocks, (1970's) we used to look for the stamped "T" in the suffix to identify a 4-bolt main bearing 350, but it seems that doesn't always work on the later models. Good luck! Jerry
| | | | | Joined: Feb 2010 Posts: 86 Shop Shark | | Shop Shark Joined: Feb 2010 Posts: 86 | the casting in the back is GM50LG . The other V1216TWB was stamped in front of the cylinders. thanks | | | | | Joined: Mar 2005 Posts: 98 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 98 | TWB 89 305 Truck 175hp L-03 TBI
50 chevy 3100
