4 members (Otto Skorzeny, mason86, dt235sd, 5 Window 9434), 83 guests, and 0 robots.
Topics128,050
Posts1,055,683
#749352 05/24/2011 5:22 AM
I bought a supposed to be a 89 305 out of a van at the auction. Can someone break down the block numbers for me.V1216TWB I need to order parts so I need to make sure what I have. thanks
I know the V is flint Micigan. The 12 and 16 are dates. But what is the TWB stand for in 1989??? thanks
I see nothing with letters for block castings. All info I have shows 8 numerals. Only 89 is for a car with roller cam. Are these numbers/letters from the rear of the block?
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
I assume the numbers are stamped on a machined pad on the block ahead of the passenger's side cylinder head? The 3-letter suffix should tell you the year and engine size if you can find the right cross-reference chart. "T" in that suffix code means it's a truck engine, but I can't seem to find the reference chart online that I usually use.
The casting number (not a stamping) at the back of the block just above the bellhousing bolt circle on the driver's side is probably a better way to do your research. On older blocks, (1970's) we used to look for the stamped "T" in the suffix to identify a 4-bolt main bearing 350, but it seems that doesn't always work on the later models. Good luck!
the casting in the back is GM50LG . The other V1216TWB was stamped in front of the cylinders. thanks
TWB 89 305 Truck 175hp L-03 TBI
50 chevy 3100
