7 members (bnauman, 1955 1 Series, Otto Skorzeny, dt235sd, Peggy M, Phak1, 1 invisible), 54 guests, and 2 robots.
Topics128,174
Posts1,057,114
Members48,463
#749022 05/22/2011 11:09 PM
Finishing up my restoration on the '50 3100 and just found out why my new fuel line won't seem to fit correctly. I guess these old trucks had a 90 degree shutoff valve at the end of an 1/8" npt pipe. I found a pipe in the glove box along with a bunch of other parts. My truck had a hose barb and a rubber hose from the tank to the fuel pump. Does anyone know where I can get a new or repo valve or is this a DIY out of parts? I'm trying to stay as original as possible. Thanks.
It never costs more to ask and it never costs more to think big.
I'm not sure if they are available new,but I imagine the survival rate of original ones would be good as they're made of brass.
Might be an idea to stick a wanted ad in the swap meet section.
The one on my own 50 was badly gummed up,but after a good soak in gas overnight it freed up nicely.......and NO you can't have it! wink
More pix on Flickr.
Jim Carter has everything you need.
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics
I don't think anyone has the repop petcock valves though, so don't throw yours away. I couldn't find a new one and kept mine, took it apart, blasted and polished it up. I used a new piece of pipe though. Works just fine.
They don't look original, but gas farm tractors had a valve like this. They are available and they serve the purpose. I use Case/IH.
Call Jim Carter and ask if he has a used valve off an old truck.
Weatherhead part# A555 is 90 degree shutoff, 1/8" male pipe to 1/4"
compression fitting. (Same as Carter's MEG137) Was about the same price at NAPA, but no shipping!!
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
