6 members (walter74, JW51, 3B, J Lucas, Joe H, 1 invisible), 86 guests, and 3 robots.
Topics128,080
Posts1,055,952
Members48,430
#748771 05/21/2011 6:34 PM
Members:
I just got my new 12v headlight switch...It looks just like the original...EXCEPT....If you look in the Manual Fig#62
http://chevy.oldcarmanualproject.com/shop/1954truck/images/54ctsm1240.jpg
Where the stop light and dome connection is...the new one has a fuse between the 2 screws?????Do I still connect the stop light and dome lamp there ?
Help.
1954 Chevy 3100 5-Window
More pix on Photobucket
"True victory is victory over one's self."
Krav Maga isn't pretty ... but it works just fine.
Jimmi V.
#748967 05/22/2011 5:47 PM
members..I know this isn't the correct place to post this,but I tried in electrical and have had no response...and it's the weekend and the candle is burning and I would like to work on Jaunita.
Members:
Help.
Jimmi V.
was there a description in the catalog? did it maybe say: "Headlight switch, 6V, new, with fused dome-stoplight-glove box circuit for trucks without an accessory fuse box" like the one at American Classic? does that answer your question? wink
No,Just said 12v headlight switch with knob....I'm assuming that you still use the terminals like the orginal...but I'm afraid to assume....just want some reassurance...
Jimmi V.
be reassured, adding a fuse changes nothing, but if you want to prove it to yourself, check the functions of the switch with an ohmeter
Thanks, I'll give it a go...
Jimmi V.
