1 members (CuzzFuzz),
228
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Members: I just got my new 12v headlight switch...It looks just like the original...EXCEPT....If you look in the Manual Fig#62 http://chevy.oldcarmanualproject.com/shop/1954truck/images/54ctsm1240.jpgWhere the stop light and dome connection is...the new one has a fuse between the 2 screws?????Do I still connect the stop light and dome lamp there ? Help. | | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | members..I know this isn't the correct place to post this,but I tried in electrical and have had no response...and it's the weekend and the candle is burning and I would like to work on Jaunita. Members: I just got my new 12v headlight switch...It looks just like the original...EXCEPT....If you look in the Manual Fig#62 http://chevy.oldcarmanualproject.com/shop/1954truck/images/54ctsm1240.jpgWhere the stop light and dome connection is...the new one has a fuse between the 2 screws?????Do I still connect the stop light and dome lamp there ? Help. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | was there a description in the catalog? did it maybe say: " Headlight switch, 6V, new, with fused dome-stoplight-glove box circuit for trucks without an accessory fuse box" like the one at American Classic? does that answer your question?  Bill | | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | No,Just said 12v headlight switch with knob....I'm assuming that you still use the terminals like the orginal...but I'm afraid to assume....just want some reassurance... Thanks | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | be reassured, adding a fuse changes nothing, but if you want to prove it to yourself, check the functions of the switch with an ohmeter
Bill | | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | Thanks, I'll give it a go... | | |
