Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (Shade Baby), 21 guests, and 4 robots.
Topics128,009
Posts1,055,293
Members48,419
#748778 05/21/2011 7:10 PM
On the block at either end of the exhaust and Intake ports are acouple studs sticking out. When the headers are placed the studs go into the hole but don't have any threads sticking out...and I can't remember if the stock exhaust had a nut on there. Or are the studs just for alignment ?
1954 Chevy 3100 5-Window
More pix on Photobucket
"True victory is victory over one's self."
Krav Maga isn't pretty ... but it works just fine.
Jimmi V.
Re: Torque Specs for manifold [Re: Jimmi_V]
Originally Posted by LONGBOX55
15-20 for the outer 4 bolts, 25-30 for the 2 next to the heat riser. I also like to remove the 2 guide pins at te very outer ends of the exhaust manifold and replace them with bolts for better sealing. I torque them to the same 15-20 ft/lbs as the others.
Carb can be installed on the manifold before or after, might be easier to hadle the manifold with it off, though.
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
Studs just for alignment
-Tom
1950 Chevy 3100 w/ 1956 235
