| | | Forums66 Topics128,088 Posts1,056,002 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#74879 03/15/2007 11:44 PM | Joined: Feb 2006 Posts: 29 Apprentice | | Apprentice Joined: Feb 2006 Posts: 29 | can anybody give me some pointers on putting a early v8 in a ad truck.i want to keep the original gearbox and closed drive line.what starter and flywheel should i use? thanks for any help cheers jonathan  | | |
#74880 03/16/2007 1:59 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | You need an early V8 truck bellhousing, flywheel and starter and convert to twelve volts. | | |
#74881 03/16/2007 2:19 AM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | If you have the original 265V8's 1955-56 exhaust manifolds I believe you won't have any clearance trouble with the steering box. At least that's what I read on here in the past. Also I believe you can fudge that steering box outboard a bit for some extra clearance. I'm sure someone will be along here to clarify. | | |
#74882 03/16/2007 8:50 AM | Joined: Feb 2006 Posts: 29 Apprentice | | Apprentice Joined: Feb 2006 Posts: 29 | the engine conversion is a job for this fall!iam converting to 12v at the moment.it will take me months to get all the parts and build the engine.thanks for the input jonathan | | |
#74883 04/21/2007 11:23 PM | Joined: Jun 2006 Posts: 4 New Guy | | New Guy Joined: Jun 2006 Posts: 4 | You can use the 55 chev v8 manifolds. The dump upwards slightly and then exit down a dump forward on drivers side and rear on passenger side. Normally you have to offset the engine about 1-1/2 inches to passenger side to make it work. I don't think it is a good idea to offset the steering box and heat-bend the pitman arm. 55 Chev manifolds will still require some offset but maybe not more than an inch or so. | | |
#74884 04/22/2007 12:24 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Those real early V-8 motors are front mount instead of side mount. If you are thinking you'll use one of the common V-8 type side mount crossmembers its not going to work.
If you swap the bellhousing crossmember for one from a '54 or '55 1st that early V-8 truck type bellhousing will easily bolt up. Otherwise you are going to need to adapt the bellhousing to a crossmember designed for a different type of mounting.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#74885 04/22/2007 12:36 AM | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | Since all the smallblock engines have the same dimensions, why would you choose a 265? Those engines were pretty puny when they were new, and 50 years of use certainly hasn't improved them. The engine mount bolt holes and bellhousing pattern are shared by all the small blocks, so why not use a 305, or even a 350? If you can locate an early V-8 bellhousing with the side mounts, and a pickup-type front horseshoe mount, the adapting will be fairly simple. The 51 never had a V-8 option, so there will be some clearance issues regardless of which engine you use. It doesn't make sense to use an antique engine when newer, more powerful ones are available. Jerry
#74886 04/22/2007 7:14 PM | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | In reading Jon's post he isn't clear which small block engine, just an early V8. I do agree with most here that given the choice I'd choose something with more muscle than a 265 or 283. Also Jon, if you haven't yet found the engine you will find those early engines are pretty scarce now days. However if that's all you got, that's all you got. Good luck buddy... send pictures...
~Jim
#74887 04/22/2007 7:17 PM | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Oh, Duh... I didn't read the topic well, 265 into a 51. Well Jon, I suppose you could always bore it out a bit.
~Jim
