4 members (baldeagle, walter74, kades51, 1955 1 Series), 70 guests, and 3 robots.
Topics128,014
Posts1,055,328
Members48,419
#748565 05/20/2011 6:51 PM
Does anybody know what headers will work on a 62 C10 with a 350 and 700R4. Hedman rep suggested the model 68390 but parts guy at scoggin dickey says if i buy and try to put them on and they dont work i may have a hard time getting hedman to take them back.
beancan #748667 05/21/2011 5:02 AM
The V8 trucks came with rams-horn manifolds, and had the exhaust pipes routed up to them. I like to keep things simple:
I'd use reproduction 2.5-inch Rams Horn manifolds, the new Speedway rams horn manifolds, a set of shorty headers, or if you've got the front saddle-mount and no side mounts, I'd maybe go with some of the reproduction Fenton Tri-Y cast iron headers.
Unless you feel you NEED full-length headers. If that's the case... then I got nuthin.
-Brad
SOUTHERN FALL GABfest
October 6 ~ Commerce, Georgia
Details here!
Never Pee on an Electric Fence.
Brad54 #748672 05/21/2011 5:26 AM
thanks for the info I will probably go with the ramhorns they would be easier to mate up to with exhaust pipes. also i will be putting on ac at some point since i want my wife to go with me in the Texas heat.Ha Ha I got a 62 cause im a 62 model myself and i am having a lot of fun with it. when i get back together i will try to post a pic. thanks again.
beancan #748706 05/21/2011 1:27 PM
The rams horn work out the best, No leaking and efficent.
gazim #748730 05/21/2011 4:01 PM
Muscle car resto houses carry 2.5-inch Rans horns, as do Dorman dealers.
The 2.5-inchers were the factory hi-perf models; others were 2.0 or even smaller.
-Brad
Details here!
Brad54 #750448 05/29/2011 3:41 PM
I had the c10 headmans on my 61. They worked ok after I hammered one tube, notched the bell housing cross member (which you already cut out or your auto trans would not fit) and relocated the brake lines for driver front. If I were to do it again, I would have used the 327 vette ramhorns like mentioned above. Thought I would chime in, just incase you had any remaining doubts about the ramhorns.
Longbed61 #751425 06/02/2011 4:26 AM
Anybody use the Sanderson shorties on their early 60's truck? I had them on a 305 sbc in my '56 Chevy and they cleared just fine. But they may not work out on the later models...
