5 members (2-Ton, rfs56trk, J Lucas, Pete O, Barry Martak), 84 guests, and 2 robots.
Topics128,094
Posts1,056,489
Members48,444
#748382 05/20/2011 12:36 AM
V
V Offline
I am looking to replace the line from the motor to the oil pressure gauge , but when I take the old one to the FLAPS all i get are stares ohwell .Seems like the old line had fittings that crimped themselves to the line as it was tightened similar to a compression fitting ,but not quite. So what am I missing? What has everyone else done?
Thanks in advance for your time.
Jessica's Truck
The true definition of insanity:
To do the same thing the same way repeatedly and expect a different result each time.
3B Offline
Hy Village_Idiot, that system was called "threaded sleeve", Weatherhead still make it. The nuts for 1/8" tube are p/n 6100X2, if you need anything else to put it back together just let us know, hope that helps.
V
V Offline
3B,
As always thanks for the info it is much appreciated.I did a google search for Weatherhead and came up with a site for Eaton which apparently bought out Weatherhead.I searched their site for part # 6100 and came up empty so I searched "threaded sleeve" and came up empty. Do you know of a supplief for this item? I even tried MSC which is a distributor of the Weatherhead fittings....just not these.
Again thank you for your time.
Jessica's Truck
chevs of the 40s has it.
link
probably other suppliers do as well.
regards,
Leon
3B Offline
Hy Village_Idiot, you are correct Eaton did acquire Weatherhead I did get a couple of 6100X2 nuts a couple of weeks ago from my FLAPS for a friends 54 Buick. When you search use the whole number "6100X2" 6100 is just the series part identifier and without the "X2" it doesn't represent a part. Any good FLAPS that has sold Weatherhead would recognise the number and would be able to check for availability if they don't stock it, hope that helps.
Weatherhead/Eaton
Brass Threaded Sleeve
Tube Connection / Fitting, 0.125 in (3.2 mm)
Part Number: WH 6100X2
Product Line: Weatherhead
$0.69 at USA NAPA
V
V Offline
Thanks everyone for all the helpful information. The wealth of knowledge here is amazing.
Your time is greatly appreciated.
Jessica's Truck
