| | | Forums66 Topics128,135 Posts1,056,423 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 127 | I am looking to replace the line from the motor to the oil pressure gauge , but when I take the old one to the FLAPS all i get are stares  .Seems like the old line had fittings that crimped themselves to the line as it was tightened similar to a compression fitting ,but not quite. So what am I missing? What has everyone else done? Thanks in advance for your time. Jessica's TruckThe true definition of insanity: To do the same thing the same way repeatedly and expect a different result each time. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Village_Idiot, that system was called "threaded sleeve", Weatherhead still make it. The nuts for 1/8" tube are p/n 6100X2, if you need anything else to put it back together just let us know, hope that helps. | | | | | Joined: Jul 2010 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 127 | 3B, As always thanks for the info it is much appreciated.I did a google search for Weatherhead and came up with a site for Eaton which apparently bought out Weatherhead.I searched their site for part # 6100 and came up empty so I searched "threaded sleeve" and came up empty. Do you know of a supplief for this item? I even tried MSC which is a distributor of the Weatherhead fittings....just not these.
Again thank you for your time. Jessica's TruckThe true definition of insanity: To do the same thing the same way repeatedly and expect a different result each time. | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | chevs of the 40s has it. link probably other suppliers do as well. regards, Leon | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Village_Idiot, you are correct Eaton did acquire Weatherhead I did get a couple of 6100X2 nuts a couple of weeks ago from my FLAPS for a friends 54 Buick. When you search use the whole number "6100X2" 6100 is just the series part identifier and without the "X2" it doesn't represent a part. Any good FLAPS that has sold Weatherhead would recognise the number and would be able to check for availability if they don't stock it, hope that helps. | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Weatherhead/Eaton Brass Threaded Sleeve Tube Connection / Fitting, 0.125 in (3.2 mm) Part Number: WH 6100X2 Product Line: Weatherhead
$0.69 at USA NAPA
| | | | | Joined: Jul 2010 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 127 | Thanks everyone for all the helpful information. The wealth of knowledge here is amazing.
Your time is greatly appreciated. Jessica's TruckThe true definition of insanity: To do the same thing the same way repeatedly and expect a different result each time. | | |
