1 members (WingWright),
103
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | Found a relined set of 2x14 brakes real cheap! Dare I use them in lieu of the original 2-1/2"x14 that are in the rear? Would there be an alignment issue? The current ones are oil soaked and the truck would never haul loads. | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | I would recommend what the OEM specs called for. In your case 2.5"x14" brake shoes. I never like "cheap" when it comes to steering and brakes. You'll have diminished stopping ability with the narrow incorrectly sized brake shoes. Also the Huck system brakes were marginal even in top working condition. (The Bendix brakes became available in '51 on 1/2 ton trucks and '52 or'53 on 1 ton and larger trucks) | | | | | Joined: Dec 2010 Posts: 15 New Guy | | New Guy Joined: Dec 2010 Posts: 15 | I would get the originals relined ASAP, don't do brakes cheap, they're there to save your life. I'll drive anything that runs crappy and stops good, but, I wont drive anthing that wont stop, no matter how great it runs.
| | | | | Joined: Feb 2008 Posts: 320 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2008 Posts: 320 | I would get the originals relined ASAP, don't do brakes cheap, they're there to save your life. I'll drive anything that runs crappy and stops good, but, I wont drive anthing that wont stop, no matter how great it runs. Amen | | | | | Joined: Jan 2011 Posts: 152 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 152 | I had jim carter reline mine, They looked good, But were bonded rather than riveted. But they work well. There price was real reasonable.
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics | | | | | Joined: Jan 2011 Posts: 35 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 35 | After hunting around for a replacement set, I had a local friction supply company reline mine for about $25/shoe. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I had mine relined on my 51 1 Ton and they work just fine. I must say there is nothing marginal about my Huck brakes. The whole thing about them being hard to operate does not apply in my case. Yes they do not have automatice adjusters but they take a lot of running before they need adjusting. | | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | 641, asbestos brake lining has not been legally manufactured in the USA since about 1980 but some is still out there if you do some searching. I recently took the so called "organic" pads and shoes off my street rod roadster and put asbestos friction on and it was like adding a power booster. I'd forgotten what an effective friction material asbestos is, and very easy on drums and rotors too.
It shows up on ebay occasionally and some of it, Gray Rock for example, is very high quality.
Asbestos is like R12 refrigerant, illegal to manufacture but not illegal to own if you can find it.
Ray
| | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | I did find a local commercial brake lining company that would do the set for about $100. Not sure if they rivet or bond. | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Got lucky and found a set of nos shoes for my 52 3804 rear brakes,on ebay,last year,for a song. Still in the GM box. As I remember it,I was the only 1 bidding. Anyway,gonna swap em out and then have a local shop reline my old cores. 25 bucks a shoe is an EXCELLANT price to pay for piece of mind AND Stopping Power. regards, steve sr. | | | | | Joined: Jul 2009 Posts: 38 New Guy | | New Guy Joined: Jul 2009 Posts: 38 | I am looking around and I swore I saw someone post part numbers for a vendor that sold drums somewhere... I want to update to Bendix from my Huck system... I am guessing I can't use the same drums? | | |
