2 members (54farmtruck, Rich'sToys), 115 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,456
I am working on my floorboards in my 59 Chevy and have a question on what appears to be some kind of vent hole on each side of the cab. The holes are roughly the size of cigarette pack that protrude down the side of the truck. They are up against each side, below the heat vents. Were these originally capped with something? Or just rust holes in my cab, that I am mistaken for something else. =) Any help appreciated.
1956 Chevy 3100 Stepside Shortbox
More pix on Photobucket
Can you post pics? Doesn't sound like anything I see on my '59.
1959 Chevy 3/4-ton (pics posted soon)
I child-proofed my house, but my kids keep finding their way back in.
"heat vents"? you must mean the fresh air vents on the kick panels, no heat involved wink behind them the cowl-top grill feeds into plenum chambers on each side, and that airway carries on below the kick panel vents to a drain at the bottom of the cab right where the lower rear fender bolt is - better start taking a closer look at how the cab is built, there's alway a lot of rust in those plenums, from the top rear fender mount point right to the bottom drain, and usually involving the lower hinge pocket as well .... probably pics in the assembly manual that show the area
Thanks for the help, but I will post some pics soon to give you a better idea of what I am talking about.
Maybe someone cut holes for a speaker?
I took a look at it again this morning. It is a small side panel that runs down to the floor and turns out about an inch, and meets the floorboard. The area that turns out to meet the floor is rusted out. Does anyone know what that piece is called? Again, I will try to get some pics posted tonight.
sounds like the welded flange at the bottom of the kick panel, and rot in that area will require some DIY fabrication - a picture might get you more help
Ifound it, it is called a Kick Panel Cover Plate. You can buy them for $30. I think I will fabricate something to get the job done. I am not fixing this truck up to win any shows. =)
