2 members (J Lucas, pauld),
123
Mod | | | Forums66 Topics128,183 Posts1,057,263 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 52 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 52 | I'm wondering if you can put a 3.55 or simular ratio in an early torque tube without using a kit?
I have a 39 car & I want to put in a ring & pinion from a powerglide rear end. Is there a way to cut & weld shaft?
Sorry...I realize this isn't a truck but I'm getting desperate to find an answer.
Any help is appreciated....thanks | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | It might be easier to swap out the complete '39 rear torque tube and replace it with the entire powerglide torque tube setup.
Drew
| | | | | Joined: Jul 2005 Posts: 52 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 52 | I agree but the powerglide tube is 3" longer. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Send a PM to Yar. I think he will give you your answers. | | |
