1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#747003 05/13/2011 2:17 PM
My axles are extremely worn and pitted on the surface where the rear wheel bearing rides. I have exhausted all local machine shops and no one around here can resurface or find a sleeve to repair the damage. Does anyone out there know of a supplier that may have a repair sleeve to fix my axles. Thanks Kenny
Kenny Martin
Talladega, Ala
Second place is the first loser - Ricky Bobby
1956 Chevy 1/2 Ton
I had the same problem. To my knowledge. no axle blanks are avaible to have new axles made. I had a 4X4 later model rear end housing narrowed and new axles made.
Toms Differentials is the only company I know of offering replacements. However, they do require changing the spider gears to the 30 spline gears from a '65 or later 12 bolt. Not necessarily a bad thing, 30 spline gears/axles are stronger than the 17 spline oe.
Bill Burmeister
I just changed the ratio of my rear end to 3.55 and had to replace both axles as the splines were chewed.
I looked everywhere and could not replacements or rebuilds.
Finally, after a lot of phone calls I found a used truck shop about an hour and half away who had several to choose from.
I bought two at $100 each they are perfect.
So, I would try the local scrap yards. It worked for me.
Peter
1951 Chevy 3100 5-Window
"Howard"
More pix on Photobucket
why not try a post in the parts wanted here for some good used axles?
Y
yar Offline
Y Offline
Kenny this subject was covered very recently on this forum. I posted a link to offset bearings that move the bearing contact surface over.
My computer skills are awful so I can't find my own post now. It's on here somewhere.
Ray
Thanks for all the info. I am going to try to find the offset bearings, if that doesn't work I will post on parts wanted for a set and keep calling local junkyards.
Thanks Again,
Kenny
Kenny Martin
Talladega, Ala
1956 Chevy 1/2 Ton
Riding in the Passing Lane
I have found that the offset brgs. dont fit these early models.
I have been known to be wrong before.
1972 Chevy c10 Cheyenne Super
Thanks for all the input. I found a set through the parts wanted section. I sure have enjoyed this site, it makes working on the old truck a lot easier with all the knowledge here.
Kenny
Kenny Martin
Talladega, Ala
1956 Chevy 1/2 Ton
