2 members (Bill Hanlon, 52Carl),
87
Mod | | | Forums66 Topics128,094 Posts1,056,058 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 115 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 115 | My axles are extremely worn and pitted on the surface where the rear wheel bearing rides. I have exhausted all local machine shops and no one around here can resurface or find a sleeve to repair the damage. Does anyone out there know of a supplier that may have a repair sleeve to fix my axles. Thanks Kenny
Kenny Martin Talladega, Ala Second place is the first loser - Ricky Bobby 1956 Chevy 1/2 Ton | | | | | Joined: Jan 2005 Posts: 75 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 75 | I had the same problem. To my knowledge. no axle blanks are avaible to have new axles made. I had a 4X4 later model rear end housing narrowed and new axles made. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Toms Differentials is the only company I know of offering replacements. However, they do require changing the spider gears to the 30 spline gears from a '65 or later 12 bolt. Not necessarily a bad thing, 30 spline gears/axles are stronger than the 17 spline oe.
Bill Burmeister | | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | I just changed the ratio of my rear end to 3.55 and had to replace both axles as the splines were chewed. I looked everywhere and could not replacements or rebuilds. Finally, after a lot of phone calls I found a used truck shop about an hour and half away who had several to choose from. I bought two at $100 each they are perfect. So, I would try the local scrap yards. It worked for me. Peter | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | why not try a post in the parts wanted here for some good used axles?
Bill | | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | Kenny this subject was covered very recently on this forum. I posted a link to offset bearings that move the bearing contact surface over.
My computer skills are awful so I can't find my own post now. It's on here somewhere.
Ray
| | | | | Joined: Dec 2010 Posts: 115 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 115 | Thanks for all the info. I am going to try to find the offset bearings, if that doesn't work I will post on parts wanted for a set and keep calling local junkyards.
Thanks Again, Kenny
Kenny Martin Talladega, Ala Second place is the first loser - Ricky Bobby 1956 Chevy 1/2 Ton | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I have found that the offset brgs. dont fit these early models. I have been known to be wrong before.
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2010 Posts: 115 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 115 | Thanks for all the input. I found a set through the parts wanted section. I sure have enjoyed this site, it makes working on the old truck a lot easier with all the knowledge here.
Kenny
