3 members (Bill Hanlon, FishinToms53, tesa), 110 guests, and 2 robots.
Topics128,087
Posts1,056,000
Members48,430
#745136 05/06/2011 6:02 AM
I'm looking for an aftermarket tachometer to put in my truck. What rpm range should I be looking for with my stock 216 and 4-spd manual?
Dave Baird
1951 Chevy 3803
Dave51Chev #745156 05/06/2011 11:30 AM
i made mine 0-35*100 with one hundred rpm increments.
51 ashton #745201 05/06/2011 3:36 PM
Where did you pick yours up at?
Dave Baird
1951 Chevy 3803
51 ashton #747730 05/17/2011 3:20 PM
51 ashton - which one did you get? I was looking at their 6v tachs a while back.
BLUEMEANIE #747857 05/17/2011 11:45 PM
i got the 3CT33-2-6V. it has a three inch face. i like it because its easy to see and read at all rpms.
51 ashton #748186 05/19/2011 4:42 AM
How is it hooked up? Did it come ready to go or did you have to modify anything on the tach or truck for it to work?
BLUEMEANIE #748217 05/19/2011 11:27 AM
mount it wherever you want. one wire goes to the dist. and one to ground. directions are in the box.
51 ashton #748276 05/19/2011 4:41 PM
Cool! I was thinking about getting one of those plastic carbon fiber a-pillar pods and mounting it directly in my line of sight along with my battery temp and blinker fluid gauges.
Just kidding. grin
I'll probably just mount it to the column somewhere. What I really meant was how it 'plugged in'. I was hoping it was close to plug and play and I wouldn't have to modify anything mechanical to get a reading.
Thanks for your input, I'll be ordering one as soon as I get the motor up and running.
BLUEMEANIE #748363 05/19/2011 11:37 PM
the only thing mechanical on it is the hose clamp that secures it to the steering column. it's so simple even a cave man could do it.
