0 members (), 140 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#747967 05/18/2011 12:26 PM
New member to this great forum. Easy question.....found an original 1952 license plate for my 1952 3100 truck and want to mount it on the front bumper. Does the bracket mount to the bumper bracket or to the splash panel? Also, what it the correct location? Left or right side or center? Any help would be greatly appreciated.
It bolts to the splash panel. I put mine on the left side as you're looking at it from the front.If you look at the Gallery on 52 trucks you'll see some on the right also, they were only installed on trucks where they had to have them.AS in Il..
Pete
Leo Offline
Moderator
Moderator
Mine is on the right side where the splash panel had two holes designed for the bracket.
Here is a factory photo for you (1951) showing the location.
http://good-times.webshots.com/photo/2799557560102454676TdvwPu
It should be on the passenger side. Why? Easier for the police to see them when driving by. It's similar reasoning for having the rear plate on the driver side.
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
Many thanks to you all for the information. Since a front plate is not required here in SC andd it will not match the rear plate, I guess it doesn't matter which side I mount it. Fortunately, new repro brackets are available from many sources.
Just purchased a 1952 3100 a few weeks ago and have been enjoying it. It underwent a complete restoration about 15 years ago but has seen plenty of use since then. As a matter of fact, the guy I bought the truck from drove it from CA to NC about ten years ago when he and his wife moved.
Thanks again.
1952 3100
SC3100
But ya can put a bracket on there correctly,and put a Vanity Plate,Historic Plate etc.
And then put a Stovebolt Topper on it!
regards,
steve sr.
