| | | Forums66 Topics128,051 Posts1,055,768 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 35 New Guy | | New Guy Joined: May 2011 Posts: 35 | New member to this great forum. Easy question.....found an original 1952 license plate for my 1952 3100 truck and want to mount it on the front bumper. Does the bracket mount to the bumper bracket or to the splash panel? Also, what it the correct location? Left or right side or center? Any help would be greatly appreciated. | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | It bolts to the splash panel. I put mine on the left side as you're looking at it from the front.If you look at the Gallery on 52 trucks you'll see some on the right also, they were only installed on trucks where they had to have them.AS in Il..
Pete
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Mine is on the right side where the splash panel had two holes designed for the bracket. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | It should be on the passenger side. Why? Easier for the police to see them when driving by. It's similar reasoning for having the rear plate on the driver side. | | | | | Joined: May 2011 Posts: 35 New Guy | | New Guy Joined: May 2011 Posts: 35 | Many thanks to you all for the information. Since a front plate is not required here in SC andd it will not match the rear plate, I guess it doesn't matter which side I mount it. Fortunately, new repro brackets are available from many sources.
Just purchased a 1952 3100 a few weeks ago and have been enjoying it. It underwent a complete restoration about 15 years ago but has seen plenty of use since then. As a matter of fact, the guy I bought the truck from drove it from CA to NC about ten years ago when he and his wife moved.
Thanks again.
1952 3100
| | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | SC3100 But ya can put a bracket on there correctly,and put a Vanity Plate,Historic Plate etc. And then put a Stovebolt Topper on it! regards, steve sr. | | |
