7 members (baldeagle, TUTS 59, niobrarafun, Nick in Manitou, lumbersawyer, SmalltownTRKGuy, 55shaker),
108
Mod | | | Forums66 Topics128,195 Posts1,057,378 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: May 2011 Posts: 91 | Hello again, gonna convert my 41 from 6 to 12 volt. i have found wiring harnesses on ebay from 85 dollars, to over 500 dollars. why the disparity? would appreciate it if someone would recommend a good mid level harness. also, can i use the oem starter and generator? if they need rebuilding, where would i send them? thanx for your help. | | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy 1fletch, the disparity will be things like the number of circuits, original style wire vs modern materials, absolutely stock vs extras, that kind of thing. You can use your original starter on 12 volts if you keep the engine in a good state of tune, so you don't have to crank the snot out of it to get it to start. The generator on the other hand would have to have different field wirings installed, not really worth the money seeing as how there are thousands of 12 volt generators out there that could be installed in place of your 6 volt generator, not to mention about "upgrading" to an alternator, hope that helps. | | | | | Joined: May 2011 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: May 2011 Posts: 91 | Thanx Shark, I'm going with a "modern" harness. I think 11 circuits should do it. That will give me the option of 2 or 3 accessories if I remember correctly. With that in mind, how much should I spend? And, I'll find a 12 generator to install. | | | | | Joined: Jan 2011 Posts: 90 New Guy | | New Guy Joined: Jan 2011 Posts: 90 | Hi 1fletch I just finished putting in an Ezwire harness in my 54 and mounted an Alternator, There are no ground wires with the Ez but the wires are marked every like 12 inches what they go too
1954 3600 With 1950's Powers of St Louis Utility Bed. My truck | | | | | Joined: Apr 2011 Posts: 106 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 106 | I just started installing an EZ harness in my 40. So far I'm impressed. It's a nice unit and I haven't encountered any issues so far. Mine is an EZ 20 mini. I think I paid $135 on ebay for it.
1940 Chevy 1/2 ton, 12 volt, 350/350th
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I used a Hot Rod Wires harness in my '56 and have another waiting to go in my '54 GMC pickup. It has GM color coded wires, larger wires than stock on things like headlight, alternator and ignition circuits and plenty of length to the wires for custom installation. | | |
