7 members (wilbur53, Rusty Rod, D B Cooper, RaNfLaS, Gdads51, KEVINSKI, 1 invisible),
114
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,060 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 50 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 50 | Does anyone know of a source to get the rear cab corner supports for the 47-48 3100 , not the center mount but the rubber corner supports. I bought the cab kit from Classic Parts but the mount is not like the original. Or does anyone know the GM part # to try to find NOS ?? Thanks in advance !! | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | are you refering to the rear Cab mount schakles? is so here is a link ...link... american classic part number CMBK5R is your truck a 1/2 ton? I thought the 48 used the one rear center mount | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I don't believe they make the cab corner supports anymore. You will have to drill holes in the middle of the old support brackets on the cab rear and use the ones that came in the kit.
The only way to get the original supports is to pray and wait for a pair of NOS to show up at either a swap meet or Ebay.
I used the supports that came in the kit on my 48 3100. They work fine.
Best of luck
Dennis -there is nothing stronger than the heart of a volunteer-
