4 members (frogfarmer, dt235sd, Frank50, 1 invisible), 267 guests, and 6 robots.
Topics128,077
Posts1,056,012
Members48,433
Does anyone know of a source to get the rear cab corner supports for the 47-48 3100 , not the center mount but the rubber corner supports. I bought the cab kit from Classic Parts but the mount is not like the original. Or does anyone know the GM part # to try to find NOS ?? Thanks in advance !!
For with God nothing shall be impossible. (Luke 1:37)
http://s224.photobucket.com/user/72cj351/library/48-52?sort=2&page=1
Paul
are you refering to the rear Cab mount schakles?
is so here is a link
...link...
american classic part number CMBK5R
is your truck a 1/2 ton?
I thought the 48 used the one rear center mount
I don't believe they make the cab corner supports anymore. You will have to drill holes in the middle of the old support brackets on the cab rear and use the ones that came in the kit.
The only way to get the original supports is to pray and wait for a pair of NOS to show up at either a swap meet or Ebay.
I used the supports that came in the kit on my 48 3100. They work fine.
Best of luck
Dennis
The part number is 3585018 47-mid 49 when they changed over. Here is a picture:
http://good-times.webshots.com/photo/2145390940102454676oOXVPC
