| | | Forums66 Topics128,281 Posts1,058,478 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 88 Shop Shark | | Shop Shark Joined: May 2008 Posts: 88 | I'm having a hard time finding a power brake conversion kit that has a 1 1/8" master cylinder, i'm thinking about just buying a kit that comes with a standard 1" bore corvette style master and then using a later model 1 1/8 master, i need to know what year chevy trucks has power drum brakes with a 1 1/8" master?? if i can just get a year or a part number i can go to the flaps and life will be alot easier and cheaper. anybody got that info??? | | | | | Joined: Nov 2005 Posts: 6,102 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,102 | Hy panman, I have found a "corvette" master cylinder which has a 1 1/8" bore, Raybestos p/n MC39018 if you wanted to use this master cylinder with drum brakes you would have to install 10 p.s.i. residual pressure valves in the ports which feed drum brakes. If at some time in the future you would like to "upgrade" to disc brakes, you could simply remove the residual pressure valve from the circuit feeding the disc brakes, and plumb the line directly from the master cylinder to the calipers, hope that helps. | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | I have a '76 Corvette master cylinder in my '48 3800. The bore is 1 1/8". It is designed for 4 wheel disc brakes but works great with the manual 4 wheel drum brake set up on my 1 ton. The push rod hole on the master cylinder is deep so it accommodates the push rod assembly. The residual valve presented a problem with very hard brake pedal and poor stopping. I removed the residual valve and the brakes work fine. The bracket assembly and extended push rod were purchased from ECI in Connecticut.This enables you to continue to use your original brake pedal set up. This set up has been in the truck for 6 years with very good stopping. | | | | | Joined: May 2008 Posts: 88 Shop Shark | | Shop Shark Joined: May 2008 Posts: 88 | thanks 3B that part number will make all the difference, i'm gonna have to get the pressuure valves for the front and back brakes, i got the big 14" drums with 2 1/2" shoes on the back and 12" drums with 2" shoes on the front, i'll never be able to upgrade to dics if you know how to do that i'm all ears, do i need to plumb the pressure valves close to the master or anywhere in the line to the drums? what size brake lines do i need to use with the valves? does it matter? i got the stock lines on the truck now i think they are 1/4" does this matter? is this master just an aftermarket universal master or is it for a specific vehicle alot of times the flaps guy's only can look it up if they know what car it fits. thanks again for the info | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | Brake lines are 1/4" all the way. You can get the '76 Corvette master cylinder from NAPA. | | | | | Joined: May 2008 Posts: 88 Shop Shark | | Shop Shark Joined: May 2008 Posts: 88 | hey wbrowne do you have a web address or contact info for that ECI place in Connecticut? i need to check out that brake bracket | | | | | Joined: Nov 2005 Posts: 6,102 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,102 | Hy panman, I just typed MCI Brakes into Google and it came up, hope that helps. | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | Hi panman, Engineered Components Inc. P.O. Box 841, Vernon, CT. 06066. 860-872-7046. Mark is the guy to talk to. He's very knowledgeable and helpful. | | |
