6 members (FishinToms53, klhansen, Hanks custodian, Mike Roache, ShopRag, Stovebolt48), 103 guests, and 0 robots.
Topics128,049
Posts1,055,634
#744617 05/04/2011 1:56 PM
Can't seem to be able to find Kroils locally. Anybody know where u can buy it or a suitable replacement? None of the "big name" auto parts stores carry it, at least around here. (Roanoke, Va.)
'52 3100 "once a Marine, always a Marine!!
Panhead59 #744625 05/04/2011 2:10 PM
You can get it thru Amazon. When you live in the back woods like I do you order alot from Amazon.
Bluesharp- If you don't blow you suck....
'50 Chevy 3600 "Ernest"
hardcrab #744648 05/04/2011 3:33 PM
google kano labratories, you can buy it directly from them, or eastwood.com sells it as well
1950 Chevy 3800
4-53T Detroit Diesel conversion
More pictures in Photobucket
Panhead59 #744666 05/04/2011 4:56 PM
Buy direct from the manufacturer in Nashville:
www.kanolabs.com
my local john deere dealer carries aerolsols. i like the gallon can. it gooooooooooooooooooooooooooooooooooooooooooes a long way i buy it buy the case
51 ashton #744729 05/04/2011 9:30 PM
Thanks everyone, I ordered some.
Panhead59 #745094 05/06/2011 3:21 AM
for those who have not ordered any lately now may be the time. I got a letter from Kano last week and the products are going up the first of June. Its not going up much but when its already a little pricey a couple dollars is right much..... but it IS the BEST!
Achipmunk #746377 05/11/2011 1:42 PM
ordered the small one, 8 ozs. I think and am supposed to get an arersol can for free. Haven't received em yet. Any day now. Must order over computer for free can.
Panhead59 #746513 05/11/2011 10:45 PM
Received the Kroil today. 8 oz. can. Put in 235 motor that sat for-ever-so-long (that's Bedford Co. Va. speak) and smoked like a train when I first started it about 2 weeks ago. I ran it some more, just in the driveway this past weekend and still smoked. Maybe not quite as bad, but still bad. You'd be embarrassed to drive it bad. Used all 8 oz. in spark plug holes. I did get 2 aerosol cans with order. They were supposed to be free. Will update this weekend on smoke and cost. Hope u guys are right, I don't want to rebuild the motor. It's only temporary while I collect all the Hot Rod parts!!! That's the current plan anyway.
Panhead59 #746581 05/12/2011 1:52 AM
The 1-gallon can is by far the best bang for the buck, and the stuff doesn't go stale. I use a small pump oiler, and the only problem is making sure it doesn't tip over- - - -the stuff will creep past any sort of threaded joint in a matter of minutes!
Edit: If you drained the oil pan first, you can recycle that 8 ounces several times. Just drain it out of the pan and pour it into the cylinders again. I've freed up rusted-tight engines with it, and it always goes through the rust, past the pistons, and ends up in the oil pan in recoverable amounts.
Too late. Already put in motor. But the next guy can use that info. Thanks. Hopefully I'll never work on enough "stuff" that requires a gal. of this Kroil. I'm gettin' too old for this rusted stuff- but yes, some people enjoy it or find it a challenge. Update on wether it worked coming up this weekend.
Panhead59 #747160 05/14/2011 4:08 AM
I use a 50/50 mix of Kroil and Shooter's Choice bore cleaner to clean my hunting and target rifles. The Ammonia in the Shooter's Choice gets the copper fouling out, and the Kroil creeps under all the powder fouling and loosens it so a clean, tight cotton patch can push it out. Clean rifles shoot little bitty groups!
What Jerry said.
Just yesterday ordered a Gal of Kroil from Kano Labs.and It,ll be here tues. or wed.
Gonna soak an old 261 that hasn,t moved a stroke since 1984
I,ll keep my guns,money and freedom...
You keep the change!
regards,
steve sr
I use a 50/50 mix of Kroil and Shooter's Choice bore cleaner to clean my hunting and target rifles. The Ammonia in the Shooter's Choice gets the copper fouling out, and the Kroil creeps under all the powder fouling and loosens it so a clean, tight cotton patch can push it out. Clean rifles shoot little bitty groups! Jerry
i was just shooting yesterday and when i was cleaning up afterwards i was wondering how hoppes #9 would work in a concoction of penetrants.
51 ashton #747511 05/16/2011 4:58 PM
Let's keep this related to trucks, please.
Cletis #748032 05/18/2011 5:40 PM
WOW
Talk about Great Service
Ordered a gal of Kroil from Kano Labs in Nashville on sat the 14th,Order placed and picked up on mon the 16th.
Just delivered to my door at 12:30.
Regards,
steve sr
P.S. Jerry,they have got to be right in your neck of the woods.
steve sr #748149 05/19/2011 2:43 AM
Yep, I can go right to their home office and pick mine up. I got started using Kroil back in the 1960's in the Air Force. It was on bench stock in every aircraft electronics shop I worked in worldwide.
