| | | Forums66 Topics128,010 Posts1,055,308 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 84 | I've got my 235 all tuned up and it runs and idles well however, once the choke (Rochester BC) has opened up, if I turn the truck off, It won't start until the engine cools down and the choke closes. I have the carb adjusted to factory settings but won't start when hot. If I choke it down, just to start it, it works fine.
Am I missing something? | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Have you tried to push the gas pedal down a few times than try and start ,when the carb is hot the gas inside perks out so if you give it a couple of shots from the accelerator pump that gives the engine some fuel to start.It worked for me when I was running a "B" carb on my 235 and 216.
Pete | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Your accel. pump may not be working good. Look down the throat of the carb with the engine off & work the throttle. You should see a squirt of gas go in each time you open it from closed possition. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
