1 members (MikeStone1953),
77
Mod | | | Forums66 Topics128,153 Posts1,056,849 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 159 | After much searching, I finally located a pair of correct style 3600 emblems for my 1953 3/4 ton. I had them rechromed ($$$) and am ready to install. But the hood has no visible dimples or drill locations. Have no idea why this is, because the truck is pretty much stock in every other way.
Anyhow, can anyone tell me exactly where they should be mounted for a 1953? Thanks!
Harry | | | | | Joined: Jan 2011 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 60 | Harryr,did you look on the inside of the hood? I have a 51 3600.I could take some pictures for you? Let me know,Thanks | | | | | Joined: Jan 2011 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 159 | Thank a lot. I did look, but it is not obvious to me. Maybe the holes or dimples were filled in by someone? So, any help would be very much appreciated.
Harry | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I saved my 3600 emblems and glad I did. Harry, what did chroming cost you?
~Jim
~Jim
| | | | | Joined: Jan 2010 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 33 | Hey Harryu, I also have a 1953 3/4 ton 3600 and have had a heck of a time trying to find the correct emblems, let along in good shape. In my profile photos it should show proper placement of the emblem. good luck
| | | | | Joined: Jan 2011 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 159 | | | | | | Joined: Jan 2011 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 159 | I paid $90 for the pair at a junkyard. The chroming shop is a very good one, and they said because it was pot metal is was a lot more labor to prepare them. They charged me $140 for the pair. Ouch! If this had been an earlier year, there is one companany that does sell 3600 repros. Can't recall which, but I have it somewhere. However, 53 and 54 were different, naturally. A heavier "art deco" design, and I wanted the correct ones. Someday I maight get it back as an investment. Or not. Doesn't matter. I feel good about it.
Harry
| | | | | Joined: Jan 2011 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 159 | Thanks, b ut not the right year - yours has the Chevrolet also - the 53-54 just have the 3600. I sort of know where they go, but I thought there would be a dimple or mark inside the hood. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I would think if the PO filled in the holes he did it with body putty. Grind off around the back side of the hood and see if you can locate the Bondo. Then again your hood might be a different vintage.
~Jim
