5 members (37 GC, Dusty53, sron48, Vice-Grip, Otto Skorzeny), 130 guests, and 0 robots.
Topics128,114
Posts1,056,613
Members48,450
After much searching, I finally located a pair of correct style 3600 emblems for my 1953 3/4 ton. I had them rechromed ($$$) and am ready to install. But the hood has no visible dimples or drill locations. Have no idea why this is, because the truck is pretty much stock in every other way.
Anyhow, can anyone tell me exactly where they should be mounted for a 1953? Thanks!
Harry
Z
Z Offline
Harryr,did you look on the inside of the hood? I have a 51 3600.I could take some pictures for you? Let me know,Thanks
Thank a lot. I did look, but it is not obvious to me. Maybe the holes or dimples were filled in by someone? So, any help would be very much appreciated.
Harry
I saved my 3600 emblems and glad I did. Harry, what did chroming cost you?
~Jim
With this link you should be able to see where the emblem goes.
http://s729.photobucket.com/albums/...RE/?action=view&current=DSC00157.jpg
~Jim
Hey Harryu, I also have a 1953 3/4 ton 3600 and have had a heck of a time trying to find the correct emblems, let along in good shape. In my profile photos it should show proper placement of the emblem.
good luck
Thank you very much!
I paid $90 for the pair at a junkyard. The chroming shop is a very good one, and they said because it was pot metal is was a lot more labor to prepare them. They charged me $140 for the pair. Ouch!
If this had been an earlier year, there is one companany that does sell 3600 repros. Can't recall which, but I have it somewhere. However, 53 and 54 were different, naturally. A heavier "art deco" design, and I wanted the correct ones. Someday I maight get it back as an investment. Or not. Doesn't matter. I feel good about it.
Harry
Thanks, b ut not the right year - yours has the Chevrolet also - the 53-54 just have the 3600. I sort of know where they go, but I thought there would be a dimple or mark inside the hood.
I would think if the PO filled in the holes he did it with body putty. Grind off around the back side of the hood and see if you can locate the Bondo. Then again your hood might be a different vintage.
~Jim
