| | | Forums66 Topics128,012 Posts1,055,311 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 164 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 164 | I just bought a SBC and 2 speed power glide from a 63 Impala. I was told it was a 327. The numbers on the ft of the block are 10424D. Can someone give me the info on this engine?
Many Thanks, Chris | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | My source shows two 327 for 1963; 3789817 and 3791362 for 62-67 bothfor 62-67' and 3794460 for 62-64'. There are a couple of others but they all have383, 3865, and 390 as the first three numbers. I show nothing with a 10424 casting number. Sorry. | | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | The only useful digit of that stamped code is the "D" which might be translated to a specific year and size engine with the right ID number list. The casting number on the driver's side of the back of the block near the bellhousing bolt circle might be more useful. http://www.yearone.com/updatedsinglepages/Id_info/gm_engine_id/gmidimages/impala63.jpgEdit: If, indeed, the engine is a 1963 model, the suffix letter indicates it was a 283 2-barrel engine. Jerry
| | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | D = 283 Powerglide
S = 327 Powerglide
1963 Passenger 283 Std. & P.G. Trans, Hyd. Cam
Block casting 3789935 3864812
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Mar 2011 Posts: 164 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 164 | Thanks guys, A 283 is not so bad,
Chris | | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | The only absolutely sure way to tell what you've got is to pull a cylinder head and measure the bore and stroke.
283: 3 7/8" bore, 3" stroke.
327: 4" bore 3 1/4" stroke Jerry
