0 members (), 101 guests, and 2 robots.
Topics128,062
Posts1,055,857
Members48,428
#747039 05/13/2011 6:03 PM
I just bought a SBC and 2 speed power glide from a 63 Impala.
I was told it was a 327. The numbers on the ft of the block are 10424D.
Can someone give me the info on this engine?
Many Thanks,
Chris
Proud Southern Stovebolter
Share the past for our future:)
1964 C10
http://s679.photobucket.com/albums/vv153/chrisgardner07/CGG_64C10/
CGG_64C10 #747043 05/13/2011 6:34 PM
My source shows two 327 for 1963; 3789817 and 3791362 for 62-67 bothfor 62-67' and 3794460 for 62-64'. There are a couple of others but they all have383, 3865, and 390 as the first three numbers. I show nothing with a 10424 casting number. Sorry.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
CGG_64C10 #747046 05/13/2011 7:00 PM
The only useful digit of that stamped code is the "D" which might be translated to a specific year and size engine with the right ID number list. The casting number on the driver's side of the back of the block near the bellhousing bolt circle might be more useful.
http://www.yearone.com/updatedsinglepages/Id_info/gm_engine_id/gmidimages/impala63.jpg
Edit: If, indeed, the engine is a 1963 model, the suffix letter indicates it was a 283 2-barrel engine.
Hotrod Lincoln #747087 05/13/2011 10:37 PM
D = 283 Powerglide
S = 327 Powerglide
1963 Passenger 283
Std. & P.G. Trans, Hyd. Cam
Block casting
3789935
3864812
-Tom
1950 Chevy 3100 w/ 1956 235
Oilrag #747095 05/13/2011 11:14 PM
Thanks guys,
A 283 is not so bad,
Chris
1964 C10
CGG_64C10 #747148 05/14/2011 3:36 AM
The only absolutely sure way to tell what you've got is to pull a cylinder head and measure the bore and stroke.
283: 3 7/8" bore, 3" stroke.
327: 4" bore 3 1/4" stroke
