4 members (Rusty Heaps, baldeagle, SWEET, NJC), 73 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
#746003 05/10/2011 12:26 AM
Hi
Just got my truck in UK today, has anyone got a link to the dashboard layout and what each button / lever does.
Thanks Gary
1954 Thames E494C,
1957 Thames 300E,
1967 Austin A60 Pick-up,
1954 Chevy 3600 Pick-up.
What year and size truck would that be?
Gary,
Does this do the trick? http://chevy.oldcarmanualproject.com/chevyowner/54tom01.htm Congratulations on the new truck.
Tim, he's a member of the "best year club".
Gary going from left too right on a 1954 you have, brake release(below dash) light switch, Pull out once for park twice for highs twist too dim gauges, High low beam should be a foot operated switch on the left one in from the foot brake, Upper dash little button knob that is for the wipers (vaccum driven) next over Right side of gauges should be choke then ignition (simple on / off) below the dash should be a lever for the cowl fresh air scoop push down and forward, then will be a radio blank plate, then the hand throttle knob , On the floor should be on the far left the foot brake Hi low beams ,the clutch, brake pedal, gas/ accelerater and finally the foot starter . If you have a whats called the fresh air heater your have controls for that too But i dont so dont know where they are situated . Congrats on getting your truck now the fun and money spending will really start lol
1954 3600 With 1950's Powers of St Louis Utility Bed.
My truck
RyanT99 #746111 05/10/2011 12:38 PM
Gary,
Congratulations on the safe arrival of your truck.
I should have looked at your old posts. Please let us know when you have started your truck (need I ask this)?
If your truck is pretty much stock, you are in luck regarding finding manuals on-line (at the website Peter linked-to above).
HI .... Thanks everyone, great help.
I have some issues to sort out, the button on top of dash does not seem to be connected at all to the wiper mechanism, are parts available ?.
Also what is the setting for the POINTS and TAPPETS.
Thanks Gary
1954 Thames E494C,
1957 Thames 300E,
Ex Hall Monitor
Ex Hall Monitor
Take the Tech Tips link at the top of the page.
Tiny #746174 05/10/2011 5:36 PM
Hi Gary setting the valves is explained here http://www.stovebolt.com/techtips/valveadjustment.htm
And in the original owners manual here
http://chevy.oldcarmanualproject.com/chevyowner/54tom24.htm
And for the points here
http://chevy.oldcarmanualproject.com/chevyowner/54tom31.htm
As for your wiper dilema , I just changed mine over to an electrical conversion.
Should you require it (and being originally from the UK so I know it rains like hell there) so you will. My advice is swap over too the electric ones. Or put in a vaccum reservior. That way when you accelerate your wipers wont stop. I used a old little camping Gas cylinder with a nipple soldered in the just hid it under the truck.
My truck
Gary,
Does your 1954 Chevrolet truck have the original radio in it? If it does, you will not find an aftermarket electric radio that will fit properly with the original speaker in place.
Is your truck still 6v?
Ryan,
Does your truck have an original radio in it? If it does and your aftermarket electrical wiper works, what is the vendor and part number of the wiper?
Is you truck and/or wiper 6v or 12v?
Tiny #746212 05/10/2011 9:00 PM
Cheers Tiny
Thanks Gary
1954 Thames E494C,
1957 Thames 300E,
Hi Tim .... a 54 3100
Thanks Gary
1954 Thames E494C,
1957 Thames 300E,
Hi Eileen
Great thank you
Thanks Gary
1954 Thames E494C,
1957 Thames 300E,
Gary,
Looking for information to answer another post of yours I ran across this. http://chevy.oldcarmanualproject.com/chevyresto/54162.htm
Hi Eileen
THANKS .... Where the THROTTLE is mine has a cigar lighter, what does it mean by throttle, surely that's the accelerator on the floor.
Thanks Gary
1954 Thames E494C,
1957 Thames 300E,
Hi Tim
No radio, it's been converted to 12v
Thanks Gary
1954 Thames E494C,
1957 Thames 300E,
Ex Hall Monitor
Ex Hall Monitor
Originally Posted by custardtart
Hi Eileen
Cheers back at ya, I'll take a whisky sour. smile Vehicles of that vintage had a hand throttle too.
