6 members (Guitplayer, Gdads51, Gray_Ghost, sron48, MRMEROTH11, 1 invisible), 89 guests, and 0 robots.
Topics128,068
Posts1,055,882
Members48,428
#746041 05/10/2011 2:32 AM
Newbie here. My dilemma: my '50 is totally dismantled, when we pulled the engine apart we noticed that the oil pan is beat up and has a 1" brazing at the lowest point on the pan. I only owned the truck for a few months before tearing it down but did not notice any leaks during that time. Engine is a '57 235.
My question: if I reuse this pan, and find in the future that it needs to be replaced, can I replace it without pulling the engine? If the answer is no, I'll just go with a new pan.
Thanks.
Newbie
1950 Chevy 3100
Welcome. Shouldn't be a problem replacing the pan with the engine in place. You may want to get several longer bolts with the heads cut off that fit in the to oil pan bolt holes to act as a guide when resetting the pan.
Where are you located in Connecticut?
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
With the engine in the truck, be sure to support the frame, not the axle, on jack stands before trying to remove the oil pan. This lets the axle hang down low enough to get the pan off the engine. If weight is on the wheels, or the stands are under the axle, there's very little clearance and the pan might not drop down low enough to clear everything.
ODSS President
ODSS President
That's a great idea.
~ Cosmo
1949 Chevy Half Ton
