6 members (MRMEROTH11, FAST55, 1955 1 Series, Hotrod Lincoln, greenie-reddy, Otto Skorzeny), 127 guests, and 1 robot.
Topics128,051
Posts1,055,768
#745559 05/08/2011 5:10 AM
i have a 1953 GMC 1 ton...
I broke apart the VIN and came up with this
1943406096
1- year. 1954
9- make. GMC
4- model. 9434
3- wheelbase. 137"
4- style. p/u delivery
06096- production number. mine was the 6096 built.
it has the original engine in it but i have no idea what it is, the VIN reads X451589
Any help?
Take the casting number from the head and from the block and look them up here: Canadian Casting Numbers Does your oil gauge go to 30 or 60 lbs? Also, does your side cover extend up over the sparkplugs?
1951 1 Ton Completed
3B Offline
Hy Josh_53GMC, Canadian serial number 1943406096 breaks down as follows
1 - year 1951
94 - GMC 3/4 - 1ton
34 - pick-up delivery 8,800 lbs. g.v.w. 137" wheelbase
06096 - is the vehicle number
1951 Canadian GMCs other than the 9700 series [3 ton] were powered by Chevrolet engines, and all but the 9700 series [3 ton] were six volt negative ground, hope that clarifies.
Look here Canadian Casting Numbers to find your casting numbers. They are raised nimbers in the head and on the block. Look here Canadian GMC Numbers to interpret your tag number on the driver's door post.
Thanks truckernix
