| | | Forums66 Topics128,209 Posts1,057,464 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: May 2011 Posts: 91 | hello just found a 1941 1.5 ton long wheelbase that had been sitting dormant on a ranch for over 50 years! the engine is froze, there is some rust to contend with, and the wiring was shot. i've got diesel fuel in the crankcase and cylinders and managed to clean 70 years of grease and dirt off the frame, engine, and body. took about 4 hours with a power washer. couple of questions. 1. where can i get a brake master cylinder rebuild kit? 2. also need brake hose and wheel cylinder kits or replacements. 3. you know what is involved getting to the back brake shoes, is it necessary to get in there just because it's been sitting? i was gonna rebuild/replace the hydraulics and then see how the brakes worked. sound ok? thanx for your input. | | | | | Joined: Aug 2010 Posts: 127 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 127 | I got all of the rebuild kits for my 41 from Napa, hoses too. I ordered hoses from Carter but they were the wrong I.D. The napa hose is about .25" longer than the OE but they work. In the end the napa kits might be okay, but I thought they were a little sloppy so I bought new wheel cylinders from Jim Carter. The M/C rebuild kit I got from napa is working well. I can't seem to find the part numbers right now for napa but they are online. Good luck, and keep us up on the progress! Rob
| | | | | Joined: May 2011 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: May 2011 Posts: 91 | thanx rob, i'll head down to napa monday. did you have any thoughts regarding the brake shoes? and, any pics of your 41? i don't see a photo link. | | | | | Joined: Aug 2010 Posts: 127 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 127 | http://www.allfrictions.com/home.html These guys will reline your shoes with new materials, at a very reasonable price. I haven't personally used them yet, they were recommended to me by a very reputable local restoration shop, as well as a friend who had them make new clutch lining for his JD 610. My truck had very low miles when I got it, and the shoes were still pretty good. I plan on having them do my shoes next winter when the truck goes back into hibernation. As for pics, I still haven't figured out how to put a link down in the signature area of my posts. I'll look into it again, but for now... http://s1112.photobucket.com/albums/k483/Hotrod_A/ | | | | | Joined: May 2011 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: May 2011 Posts: 91 | hey hotrod
just go to the toolbar and click on "my stuff." then click on "edit profile." at the bottom you will see a place to create a "signature block." go to your photobucket site and "cut" your personal address. come back to your signature block and paste your photobucket address there. hope this works for you!
| | | | | Joined: Aug 2010 Posts: 127 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 127 | Thanks fletch, I don't know why I didn't figure that out before. | | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | napa will also reline your shoes dont cost much. philip | | | | | Joined: Aug 2010 Posts: 127 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 127 | napa will reline with new material or nos that you give them? | | | | | Joined: May 2011 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: May 2011 Posts: 91 | hey philip, hotrod, thanx so much for your help. i will take my oem shoes in to be relined. ~f | | |
