1 members (Eileen),
271
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 105 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 105 | On my cooling system on my 1965 292 inline 6. i ordered a waterpump form rockauto. when i got it it has an extra pipe coming off it. looks like it is the bypass hose. the water pump I have on this engine just has the big outlet going to the bottom side of the radiator and then small one to the heater. it doesn't have the bypass of anykind. So I guess its the wrong one on the truck. what do I do? where do I find where the bypass hooks up to the thermastat housing. and what is missing.
will the none bypass pump work?? its been working. the radiator is plugged up tighter than fort knox. at least about a 3rd of it is. thanks mark | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | if it's a threaded opening, just pop a plug in it
Bill | | | | | Joined: Oct 2009 Posts: 105 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 105 | i have a water pump from a 230 motor. wondering if it will work on the 292 till i can find a water neck with extra port for the bypass. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | | | | | | Joined: Oct 2009 Posts: 105 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 105 | Thanks Tony. I guess ill be getting that book also.
Now were do I get the thermostat houseing water neak with the extra hole for the bypass?? Mark | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | | | |
