5 members (WICruiser, Hotrod Lincoln, moparguy, Barney1951, Peggy M), 54 guests, and 2 robots.
Topics128,076
Posts1,055,920
Members48,429
#745565 05/08/2011 5:24 AM
On my cooling system on my 1965 292 inline 6. i ordered a waterpump form rockauto. when i got it it has an extra pipe coming off it. looks like it is the bypass hose. the water pump I have on this engine just has the big outlet going to the bottom side of the radiator and then small one to the heater. it doesn't have the bypass of anykind. So I guess its the wrong one on the truck. what do I do? where do I find where the bypass hooks up to the thermastat housing. and what is missing.
will the none bypass pump work?? its been working. the radiator is plugged up tighter than fort knox. at least about a 3rd of it is. thanks mark
if it's a threaded opening, just pop a plug in it
i have a water pump from a 230 motor. wondering if it will work on the 292 till i can find a water neck with extra port for the bypass.
This is a great reference manual for things like this:
1960-1966 CHEV/GMC TRUCK FACTORY ASSEMBLY INSTRUCTION MANUAL
Thanks Tony. I guess ill be getting that book also.
Now were do I get the thermostat houseing water neak with the extra hole for the bypass?? Mark
You have a PM.
