| | | Forums66 Topics128,032 Posts1,055,517 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 174 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 174 | i have a 1953 GMC 1 ton... I broke apart the VIN and came up with this
1943406096 1- year. 1954 9- make. GMC 4- model. 9434 3- wheelbase. 137" 4- style. p/u delivery 06096- production number. mine was the 6096 built.
it has the original engine in it but i have no idea what it is, the VIN reads X451589
Any help? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Take the casting number from the head and from the block and look them up here: Canadian Casting Numbers Does your oil gauge go to 30 or 60 lbs? Also, does your side cover extend up over the sparkplugs? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Josh_53GMC, Canadian serial number 1943406096 breaks down as follows 1 - year 1951 94 - GMC 3/4 - 1ton 34 - pick-up delivery 8,800 lbs. g.v.w. 137" wheelbase 06096 - is the vehicle number 1951 Canadian GMCs other than the 9700 series [3 ton] were powered by Chevrolet engines, and all but the 9700 series [3 ton] were six volt negative ground, hope that clarifies. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Look here Canadian Casting Numbers to find your casting numbers. They are raised nimbers in the head and on the block. Look here Canadian GMC Numbers to interpret your tag number on the driver's door post. | | | | | Joined: Apr 2011 Posts: 174 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 174 | | | |
