7 members (Wrenchman, Oswald, Chris's 46 / 515, 55shaker, carbking, WICruiser, 1 invisible), 52 guests, and 2 robots.
Topics128,089
Posts1,056,009
Members48,430
#74515 03/08/2007 7:37 PM
I've got a 1961 3/4 ton rearend was wondering if anyone has any info, specs, where these posi or limited slip, gear ratios, any info would be helpful. thanks aaron
#74516 03/08/2007 7:40 PM
Pull the inspection cover off,,that'll tell you everything.
Marty
#74517 03/08/2007 8:02 PM
Pulled the back cover off its a 10 bolt haven't found anything but one set of numbers thats eligible first 3 digits are 388 does this mean anything?
#74518 03/08/2007 9:08 PM
That 388 is prolly just a part #, usually near this they stamped the # of teeth, but not always. If there is anything there except side gears & spider gears(like springs/plates), it is a posi/limited slip/locker whathaveyou. If nothing stamped, count the ring gear & pinion teeth to determine the ratio. Should be an Eaton, prolly 4.56. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
