Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (BC59, Otto Skorzeny, Youngin' Tut 59, TooMany2count, 1 invisible), 126 guests, and 5 robots.
Topics128,277
Posts1,058,441
Members48,490
#745034 05/05/2011 11:20 PM
Im still having trouble removing the drum from the passenger side rear of my 52 3600. I removed the two screws and have beat it with a hammer. It jiggles a bit and still will not come off. The axle spins free so the brakes are not locked. Am I not thinking of something here? I feel like an idiot.
Joshua #745039 05/05/2011 11:38 PM
Try backing the adjusters off, it probably has a wear groove and the shoes are holding it on even though the drum spins freely.
Socket Breaker
Socket Breaker
What waldo53 wrote... stick a flat blade screwdriver in the hole on the back plate where the adjusters are and back 'em off... a lot!
Then the drum should come off with some wiggling around.
-W
