0 members (), 51 guests, and 7 robots.
Topics128,021
Posts1,055,355
Members48,420
#745020 05/05/2011 10:18 PM
I have front disk brakes on my 50 3100. I installed a rack an pinion steering and ran into a clearance problem with the new steering arms they wont clear the caliper housing and I was wondering if I can turn the calipers around and have them on the front side of the spindles instead of behind.
You will have to swap them from side to side as well to keep the bleeder screw at the top. Will the calipers still bolt to the spindle brackets with all the flipping/swapping you will need to do?
There are also various aftermarket caliper brackets around for different front end setups. You may be able to find one that works for you
1940 Chevy KC 1/2-Ton
I was able to swithg them using the same brackets. But i will have to buy longer brake hoses. Thanks for the help
