2 members (Joe H, PAUL Berardi), 140 guests, and 2 robots.
Topics128,111
Posts1,056,246
Members48,437
I inherited a 250 six in my '55-2 GMC and have added a Holley 390 and headers...I am using ported vac. for the stock dist. it seems to run better than manf. vac....What total advance should I shoot for ?
Bear
1955 2nd Series GMC
More pix in Photobucket
Drive 'em and enjoy 'em.... don't haul 'em....
It depends on many things of course (cam, ignition system, etc.) but total advance will probably be in the 35 degree range, give or take a smidgeon. Does it have a HEI?
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Nope...Just a standard dist. and don't know about the cam...stock probably...when I got it there was a 1 brl and stock intake and exhaust manf...,but it had about 5k on a rebuild...I am not sure what year the motor is...compression was 110 all across...I could get some casting ,stamp numbers and throw them out for id if needed...
Bear
1955 2nd Series GMC
J Online: Content
A 250 is a 250 no matter what year, they were all the same with the same heads and compression.
Depending on your fuel supply in your area, 34 to 36 total timing is about right, if you have crappy gas, back it off a little. I could never get mine to ping since the compression is 8 to 1. so set it at 35 total. I could go higher, but it didn't run any better. It runs just fine where it is, couldn't tell you what it is at idle, don't really care, thats not where it matters.
Joe
