5 members (Ridgeback, Scott, Joe H, 3B, 46 Texaco), 68 guests, and 4 robots.
Topics128,185
Posts1,057,279
Members48,467
I hate to ask this but can someone tell me the bolt sizes that mount water pump and thermostat housing to the motor? Also will a thermostat housing from a 235 also fit a 216? I have someone that has a 235 housing, but he's not sure it will fit on 216 head. Thanks!
I can tell you the mounting pattern for the thermostat housing is the same.
As far as bolt size for the pump, they all use 3/8" bolts, but the length varies depending on what year you have.
My Blog
its a 50 216 block. I have one bolt, but missing the other 2 on water pump and none for housing.
