| | | Forums66 Topics128,162 Posts1,057,058 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 14 New Guy | | New Guy Joined: Apr 2011 Posts: 14 | I hate to ask this but can someone tell me the bolt sizes that mount water pump and thermostat housing to the motor? Also will a thermostat housing from a 235 also fit a 216? I have someone that has a 235 housing, but he's not sure it will fit on 216 head. Thanks! | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I can tell you the mounting pattern for the thermostat housing is the same. As far as bolt size for the pump, they all use 3/8" bolts, but the length varies depending on what year you have.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2011 Posts: 14 New Guy | | New Guy Joined: Apr 2011 Posts: 14 | its a 50 216 block. I have one bolt, but missing the other 2 on water pump and none for housing.
