4 members (Wayne67vert, delky, Peggy M, 1 invisible), 87 guests, and 2 robots.
Topics128,060
Posts1,055,839
Members48,427
does anyone have a recommendation for a 80-100 amp alternator? part # (napa etc.). my generator finally crapped out and instead of rebuilding, i'm going to upgrade to an alternator. thanks for your time. -DVZ
i looked at the mad electrical link on alternators and i know that i want to get a single wire, however i'm unsure about the position (i.e. 3:00). its for a 235 engine. no a/c or anything like that just replacing the 12v gen with "v" grove. -DVZ
your best bet would be to check the wrecking yards, you're gonna need the mounts and adjuster arm from a later GM 6, like the 230/250, might find the whole works at a good price .... also if you don't have a lot of extra electrical goodies you could do fine with 45-65 amp
thanks bill. i just have a radio in it. nothing fancy. i have a friend w/ a machine shop, so fabbing the mounts wont be a problem. i just wanted to go w/ a new alternator due to my luck. something about a warranty eases my mind. i was told i could obtain one from NAPA for around 60-80 bucks-DVZ
I found a 63 amp 10SI alternator off a 250 and Im also using the base that bolts to the block. Im goin to fab up an adjuster at work tomorrow so that it fits the 235
Ex Hall Monitor
Ex Hall Monitor
I bought my 6v alternator & mount from these folks. The mounts are a bit on the expensive side.
