2 members (Ponchogl, Hush),
67
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 68 | does anyone have a recommendation for a 80-100 amp alternator? part # (napa etc.). my generator finally crapped out and instead of rebuilding, i'm going to upgrade to an alternator. thanks for your time. -DVZ | | | | | Joined: Jan 2011 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 68 | i looked at the mad electrical link on alternators and i know that i want to get a single wire, however i'm unsure about the position (i.e. 3:00). its for a 235 engine. no a/c or anything like that just replacing the 12v gen with "v" grove. -DVZ | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | your best bet would be to check the wrecking yards, you're gonna need the mounts and adjuster arm from a later GM 6, like the 230/250, might find the whole works at a good price .... also if you don't have a lot of extra electrical goodies you could do fine with 45-65 amp
Bill | | | | | Joined: Jan 2011 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 68 | thanks bill. i just have a radio in it. nothing fancy. i have a friend w/ a machine shop, so fabbing the mounts wont be a problem. i just wanted to go w/ a new alternator due to my luck. something about a warranty eases my mind. i was told i could obtain one from NAPA for around 60-80 bucks-DVZ | | | | | Joined: Sep 2008 Posts: 84 New Guy | | New Guy Joined: Sep 2008 Posts: 84 | I found a 63 amp 10SI alternator off a 250 and Im also using the base that bolts to the block. Im goin to fab up an adjuster at work tomorrow so that it fits the 235
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I bought my 6v alternator & mount from these folks. The mounts are a bit on the expensive side.
