0 members (),
54
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 18 New Guy | | New Guy Joined: May 2010 Posts: 18 | I have a 1951 235 block with casting number 3692703. The Stovebolt casting page says it's a passenger powerglide. My head has the casting number 3835909. Two heads match with my block, the above mentioned 3835909 and casting 3835499. When I went change the head gasket, I noticed two water port holes on the head (between the second and third spark plug and fourth and fifth spark plug) that aren't on the head gasket or block. The whole setup is in a '46 2 ton, so I know many things have been swapped. My question is: is there a difference between the head with casting number 3835909 and 3835499? Is one meant for the truck block and one for the passenger block? I'm rebuilding the whole thing, so the new head gasket isn't due to gasket failure. What's the difference between engines equipped with powerglide and truck engines (besides the actual transmission itself). Thanks, guys... | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | I know the later powerglides were drilled for hydraulic lifters and the truck blocks typically were not.
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I haven't checked as I'm in a hurry to leave but what comes to mind is the possibility of a 261 head - steam holes? | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | I believe the holes you are looking at were for removing the casting core sand similar to the "frost plug" holes on the block and are intended to be sealed off by the gasket. Are you saying one of these heads has the holes and the other does not?
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | 1950-52 Truck 235 block casting 3692703 w/ head casting 3835909 or 3835499
1950-52 Passenger 235 - Hyd. Cam had a different block but used the same head casting as truck 3835909 or 3835499
Head Casting 3835499 is also listed for the 261.
For the 261, part # 3703569
and the 1950-52 235, part # 3835545
Same casting #, two different heads....
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: May 2010 Posts: 18 New Guy | | New Guy Joined: May 2010 Posts: 18 | Thanks, guys! I was assuming the two holes were water, but casting core holes sounds about right. Just worried me and I wanted to double check... | | |
