| | | Forums66 Topics128,054 Posts1,055,781 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 64 | Does anyone know a source for the torque tube bell collar seals for a '36 1 1/2 ton ? None of the regular vendors list them. I've got the engine and trans back in the frame and itchin to take a ride around the yard. Thanks, David | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If you buy the trans gasket set it includes them. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | You might be interested in this post. They used an o ring instead on a later Chev. Post by Chipper | | | | | Joined: Dec 2010 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 64 | Thanks for the advice. I am using o-rings in the tube end of the bell but had not considered using them on the bell. Who sells the transmission gasket set that includes the seals ? I just borrowed a Felpro ball gasket set from a neighbor and it's odd because it includes the large (4" O.D.) corks but the shim kit does not fit at all.
| | | | | Joined: Dec 2010 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 64 | Hi Wrenchbender Ret., Well I have been all over this and checked with Best Gasket and Olson too. It seems that the 1/2 ton set is readily available but nothing for the 1 1/2 ton. Any advice would be greatly appreciated. | | |
