4 members (Otto Skorzeny, Wayne67vert, klhansen, TUTS 59), 74 guests, and 1 robot.
Topics128,051
Posts1,055,764
#744542 05/04/2011 4:34 AM
Does anyone know a source for the torque tube bell collar seals for a '36 1 1/2 ton ? None of the regular vendors list them. I've got the engine and trans back in the frame and itchin to take a ride around the yard. Thanks, David
dmart #744566 05/04/2011 5:31 AM
Riding in the Passing Lane
If you buy the trans gasket set it includes them.
1972 Chevy c10 Cheyenne Super
You might be interested in this post. They used an o ring instead on a later Chev. Post by Chipper
1951 1 Ton Completed
truckernix #744742 05/04/2011 10:18 PM
Thanks for the advice. I am using o-rings in the tube end of the bell but had not considered using them on the bell. Who sells the transmission gasket set that includes the seals ? I just borrowed a Felpro ball gasket set from a neighbor and it's odd because it includes the large (4" O.D.) corks but the shim kit does not fit at all.
Hi Wrenchbender Ret.,
Well I have been all over this and checked with Best Gasket and Olson too. It seems that the 1/2 ton set is readily available but nothing for the 1 1/2 ton. Any advice would be greatly appreciated.
