| | | Forums66 Topics128,051 Posts1,055,764 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Any one have experience with these in a 216? I was getting some Marvel, degreaser, a gasket and a valve spring compressor and I decided to ask if hey had em. They did and they're $3 something each. So I ordered in a set of 12. If they're crap, I can return them. I think they're the same ones NAPA sells. | | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | Autozone sells Melling and NAPA sells Sealed power.Melling is a good brand as is Sealed power in my opinion.I use more NAPA parts than Aotozone only because the service is better for me here. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | A-Z does a good job as does O'Reilly's and both are making it very tough on NAPA IMO. | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Thanks guys! AZ is much closer for me and I found NAPA to be about the same price wise for most stuff. Not that I rule them out, I generally call around before leaving the house. Got em all on speed dial. | | |
