8 members (1955 1 Series, 39Master85, 5 Window 9434, 52Carl, Hotrod Lincoln, UtahYork, Bill Hanlon, 1 invisible), 117 guests, and 3 robots.
Topics128,089
Posts1,056,355
Members48,442
#743937 05/01/2011 9:46 PM
There is no oil getting to the valve side of the rocker arm assembly on my 235. There is plenty of oil getting to the push rod side and coming out of the holes on the rocker arms. I set intakes to .008 and exhaust to .020. Any suggestions or ideas as to why this is happening?
Ex Hall Monitor
Ex Hall Monitor
You're pretty loose on your exhaust lash (should be .013) and a tad loose on your intake (sb .006). If you're getting oil out of the top of the rockers you're good to go. You'll get enough splash & oil vapor to keep everything kosher when the engine is up to speed and hot.
Thanks, Tiny. I guess I was trying to play it safe with the exhaust and overshot it. I'll readjust and not worry about the oil on the valve side.
Tiny is correct, very little oil gets to the valves.
1929-31 chevs only oiled the push rods, none to the valves.
My Blog
I reset the valves to .013 on the exhaust and .006 on the intake. It made a huge difference, but I can't seem to get the idle set. The manual calls for 550 rpm, but when I get near 650 and below, the engine acts like it wants to cut off (and most of the time does). I was hoping the valve job would take care of it. The idle mixture screw is about 1.5 turns out and the throttle screw is about three turns out. Should I advance the distributor? It's timed to the steel ball on the flywheel. Also, just out of curiosity, is idling at 650 rpm a bad thing (besides fuel economy)? It's a '51 235 fresh rebuild...
The engine was designed to give it's best performance with the timeing set to the ball, unless you have modified the engine or know more than the engineers the designed the chevy inline six.
Adjust your idle mixture in and out till you hit the "sweet spot", the setting listed in the service and repair manuals is only a starting point.
That engine with a fresh valve job and tume-up should idle down to 450-550 rpm and be as smooth as silk.
DG
Denny G
Sandwich, IL
Thanks, Denny. I'll mess around with it today and see if I can't find that sweet spot. Should I try any adjustments on the throttle screw or play with them both or get the rpms down close with one screw and the take over and do the fine tuning with the other? As far as engine mods go, it has and HEI in it and the cylinders were bored 30 over (I don't know if that counts as a modification though).
