2 members (Materman, 1 invisible), 111 guests, and 3 robots.
Topics128,072
Posts1,055,906
Members48,429
#743972 05/01/2011 11:57 PM
I have a 53 half ton 216 engine.Does anyone know what the yellowish translucent coating is on the carb body? What color should the linkage arms etc. be? your help would be appreciated. thank you , babe
babe #744014 05/02/2011 2:22 AM
Sounds like some old dried on gas or something else got on the carb. Most are just the aluminum color, not painted. I bet a little carb cleaner will take it right off.
'52 3100 "once a Marine, always a Marine!!
Mine was that color as well. You can clean it with some carb cleaner and a brass brush and it will clean up real nice.
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
Carburetion specialist
Rochester used a cold dip chromate solution to semi-protect the zinc alloy castings (airhorn and bowl). This solution is a mixture of nitric, sulphuric, and chromic acids; AND SHOULD NOT BE TRIED AT HOME! Chromic acid is NOT a nice chemical. This process was done, not to make the carburetor pretty, but to semi-protect it from oxidation. This process is more critical today with the alcohol in the fuel. The aftermarket paint offers no protection to the inside of the carburetor.
Rochester "parkerized" the cast iron throttle bodies. This is a "blacking" process similar to gun bluing.
Rochester electroplated steel pieces with "yellow" zinc. For those who are unaware, the steel would be electroplated with white zinc, and then dipped in a "yellow conversion coat". This is a finish that evokes argument among enthusiasts, as with time, the yellow conversion will disappear, leaving a white zinc appearance.
Rochester used the yellow zinc finish on steel screws up until about 1955~1956. Somewhere in that period, the standard for steel screws changed from yellow zinc to black oxide. This probably creates the most argument among enthusiasts, as the standard changed, but THE PART NUMBERS DID NOT CHANGE! I have many new old stock Rochester screws in the original see through plastic bags where two different bags with the same part number will have different finishes on the screws.
The yellow zinc electroplate disappeared in the early 1970's when a better finish (di-chromate) became prevalent.
Remember however, that the entire purpose of Rochester finishes was protection, not appearance. This differs with some other carburetors (ie the Chevrolet Corvair turbo) in which the finish was both protection AND appearance. The Turbo Corvair carb was painted gloss black after the chromate solution was applied, and all external steel components were chrome plated.
Jon.
The Carburetor Shop
Thank you for the info on carb color. Now I have to find out if that process can still be done , and if anybody knows of a company that can do it. If anybody knows, reply would be appreciated. Thank you. Babe
babe #744322 05/03/2011 1:47 PM
carbking that posted info for you has a shop, but I think I recall him saying something about not handling Rochesters much anymore. Check with him to be sure.
http://www.thecarburetorshop.com/
Drew
