| | | Forums66 Topics128,050 Posts1,055,759 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 16 New Guy | | New Guy Joined: Apr 2011 Posts: 16 | I have a 53 half ton 216 engine.Does anyone know what the yellowish translucent coating is on the carb body? What color should the linkage arms etc. be? your help would be appreciated. thank you , babe | | | | | Joined: Nov 2010 Posts: 304 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 304 | Sounds like some old dried on gas or something else got on the carb. Most are just the aluminum color, not painted. I bet a little carb cleaner will take it right off.
'52 3100 "once a Marine, always a Marine!! | | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | Mine was that color as well. You can clean it with some carb cleaner and a brass brush and it will clean up real nice. | | | | | Joined: Nov 2002 Posts: 2,765 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,765 | Rochester used a cold dip chromate solution to semi-protect the zinc alloy castings (airhorn and bowl). This solution is a mixture of nitric, sulphuric, and chromic acids; AND SHOULD NOT BE TRIED AT HOME! Chromic acid is NOT a nice chemical. This process was done, not to make the carburetor pretty, but to semi-protect it from oxidation. This process is more critical today with the alcohol in the fuel. The aftermarket paint offers no protection to the inside of the carburetor.
Rochester "parkerized" the cast iron throttle bodies. This is a "blacking" process similar to gun bluing.
Rochester electroplated steel pieces with "yellow" zinc. For those who are unaware, the steel would be electroplated with white zinc, and then dipped in a "yellow conversion coat". This is a finish that evokes argument among enthusiasts, as with time, the yellow conversion will disappear, leaving a white zinc appearance.
Rochester used the yellow zinc finish on steel screws up until about 1955~1956. Somewhere in that period, the standard for steel screws changed from yellow zinc to black oxide. This probably creates the most argument among enthusiasts, as the standard changed, but THE PART NUMBERS DID NOT CHANGE! I have many new old stock Rochester screws in the original see through plastic bags where two different bags with the same part number will have different finishes on the screws.
The yellow zinc electroplate disappeared in the early 1970's when a better finish (di-chromate) became prevalent.
Remember however, that the entire purpose of Rochester finishes was protection, not appearance. This differs with some other carburetors (ie the Chevrolet Corvair turbo) in which the finish was both protection AND appearance. The Turbo Corvair carb was painted gloss black after the chromate solution was applied, and all external steel components were chrome plated.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Apr 2011 Posts: 16 New Guy | | New Guy Joined: Apr 2011 Posts: 16 | Thank you for the info on carb color. Now I have to find out if that process can still be done , and if anybody knows of a company that can do it. If anybody knows, reply would be appreciated. Thank you. Babe | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | carbking that posted info for you has a shop, but I think I recall him saying something about not handling Rochesters much anymore. Check with him to be sure. http://www.thecarburetorshop.com/
Drew
